SOURCE: Warning light
hi wuds
im dave
sounds like your coolant light or charging light
check your temperature guage while car is hot and coolant level while car is cold
check your charging system with a multimeter
12.8volts @ battery while car is off
14.4-14.8 V with car running
SOURCE: Toyota Corolla Spacio Warning Light
That is the tire pressure monitoring light. Simply air up your tires and it will turn off. If it comes back on then you may have a slow leak.
SOURCE: What does it mean warning light (ABS) in front
a.b.s. is anti-lock braking system.if this light is on the automatic brake pumping system is malfunctioning. you probably have standard brakes, but you need to have it checked by a reputable garage.
SOURCE: Warning light: Tell tale light showing all the time
I have a similar problem, The light is showing on when car on idle.
do anybody know what to do to fix it and if is an important fault as I have a 1000+ miles jurney coming up.
Many thanks
SOURCE: a blue warning light keeps
It is a low coolant temperature light. IT is normal for the light to come on when starting the engine from cold but should go out after a couple of miles, if not then consult a dealer.
Hi gavin ward, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? the make and model
