Cars & Trucks Logo
A
Anonymous Posted on Jan 27, 2016
What does low oil pressure on 2008 Chevy Impala 3.5 V6 LS
Aced
Level 2:
Sergeant:
Habit-Forming:
  • Expert 54 Answers
  • Posted on Jan 27, 2016
Aced
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
54
Questions
Helped
39320
Points
668
paulmacintyre
Level 3:
  • Cars & Trucks Master 3,218 Answers
paulmacintyre
Level 3:
Answers
3218
Questions
0
Helped
968529
Points
11418
Do you mean what causes low oil pressure? This is a very reliable engine for the most part. If the oil light is on or gauge is reading low, have the oil pressure sensor inspected for failure. These sensors do go bad.
5 Related Answers
Anonymous
  • 135 Answers
  • Posted on Jun 19, 2009
SOURCE: 2006 Impala 3.9 low oil pressure alarm
has a bad oil sending unit,try to replace the oil sender and it sound fix the problem,thanks robert b.
Anonymous
  • 10 Answers
  • Posted on Jun 28, 2009
SOURCE: 2000 chevy impala a/c low pressure port
PASS SIDE BY THE DRYER NEAR FIRE WALL.
Anonymous
  • 39 Answers
  • Posted on Jul 02, 2009
SOURCE: reset message center window
THIS SHOULD HELP YOU
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHG OIL SOON light flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio®. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to verify the exit.
Anonymous
  • Posted on Aug 02, 2009
SOURCE: Need to find Low Pressure A?C Port 2001 Impala 3.8
The low pressure port is against the fire wall, look straight back and you will see it.
Greg
Anonymous
  • 7353 Answers
  • Posted on Dec 16, 2009
SOURCE: Replacing Oil Pressure Sensor.
Usually near the filter.
Diagrama de encendido Chevy Impala LS 2008
Aqu? tienes el diagrama de encendido para un Chevy Impala LS del a?o 2008 con motor de 3.5 litros:
Frente del veh?culo
2 4 6 1 3 5
BOBINA 2 BOBINA 3
BUJ?A 2 BUJ?A 3
BOBINA 1 BOBINA 4
BUJ?A 1 BUJ?A 4
BOBINA 6 BOBINA 5
BUJ?A 6 BUJ?A 5
Recuerda que este diagrama representa la secuencia de encendido de las bobinas y buj?as en un motor de 6 cilindros. Aseg?rate de seguir las recomendaciones del fabricante en cuanto a las especificaciones de las buj?as y los intervalos de mantenimiento para garantizar un funcionamiento ?ptimo de tu Chevy Impala LS 2008.
Where is the Low Pressure Port located on the 2002 Chevy Impala LS
Behind the passenger side of the engine near the firewall if you have the 3400 v6.
My 2008 Chevy impala dash says low oil pressure what does that mean?
Several things: 1. Faulty oil pressure sensor (replace it (cheap)) 2.. insufficient oil (check it (cheap)) 3. blocked oil filter or oil journals (replace it and change oil) 4. oil pump failing (garage job) 5. badly worn engine bearings (garage job - usually expensive.)
Whatever it is, you should check it NOW. If you wait very long, the engine will fail.
Where is the oil pressure sensor on a 2007 Impala LS 3500 V6?
I think it is located near the bottom of the oil pan on the back side, you will probably have to drain the oil but I'm not sure. That is where mine is located however mine is a 2000 Chevy Impala LS.
What does it mean when the message "STOP ENGINE, Oil pressure low on a 2007 impala
it means the oil pressure is low and may be low enough to damage the engine if you keep drving/running the engine. it would help if you could tell us the actual oil pressure, engine and mileage . basically, the oil pressure may be low enough to wreck your engine, then again it may be bs......
6helpful
I have a 2008 chevy impala. The car suddenly
ur vehicle is in limp mode[ a safe mode ] which will get u home trying not to cause any damage to engine --theirs a few reasons the vehicle will do this-low oil pressure-transmission problem-have vehicle scanned most auto stores such as auto zone / advanced auto [check ur local area]do this service for free the code gives u a start point towards resolving ur problem
4helpful
2answers
Firing order for plugs and wires....on a v6 3800 2000 impala
For the 2000 Chevrolet Impala 3.8L V6:
Firing Order:
1-6-5-4-3-2
Cylinders:
.....(back).....
|...2...4...6...|
___________
|...1...3...5...|
.....(front)
Ignition Coil Connections:
(back)
o <---6
___
o <---3
o <---2
___
o <---5
o <---4
___
o <---1
(front)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Where is the oil filter 07 Impala
The oil filter on the 2008 Chevy Impala 3.5 V6 is located to the front center of the engine and recessed underneath and slightly to the right (passenger) side just behind the front frame crossmember.
PLEASE RATE THIS INFO
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
