SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
SOURCE: cant hear my cable channels through my surround sound...
Hello, i just saw your post.. i know this reply is so late, and you might have probably found a solution. But i will still give you some guides to help you figure this out.
(1) First and foremost, make sure your connections are set up properly (exactly as in the manual). most HDTV'S require a DIGITAL OPTICAL CABLE to be connected from TV to receiver. Read the manual on your TV and see the required wires for external audio
(2) go to your TV audio settings. Get to the speaker option, and turn it off ( this assumes your expensive TV is an HDTV). By turning it off, you signify that you want the sound option to come only from the speakers.
Hope it helps
SOURCE: Need to remove base from Venturer 26'' LCD TV
look on the tv above where the base slides into the tv and you will see screws. unscrew those screws and lift the tv off of the base.
please mark my answer as a fixya!
SOURCE: Looking the Venturer TV code for my cable remote control.
There was a piece of paper with my 10" Venturer TV that sat what other brand TV codes to use.Check the papers that came with your TV
1 Check the antenna. Adjust it to see if the picture improves. Confirm that the antenna cable is firmly connected. Check to see that input cables are connected.
