Aug 7, 2009 - ... Ademco ?€?Vista series?€ alarm system and you don?€™t knowwhat the codes are. ... The master code is the main user?€™s regular code, but different than the ... Be advised that an installing alarm company will not and should not... The master code can change or add the other SU?€™s as needed ...
I think that the sim security is active, you need to disable it with the security code.If you do not remember don't think that you can unlock byentering wrong code repeatedly coz the sim will damage.In case if you know the code Open >> menu >> Security>>Pin Code Request>> and turn it off by entering the code.But if you don' know the code contact mobile repairing shop because you could not fix it by yourself (You phone has no USB connection).Good luck
You don't know the security code? You can reset the phone using the master reset code,get the master reset code from the site Unlock-free.com and reset from security lock of NOKIA DCT or ALCTEL phones.
Don't worry you can reset the Nokia 1600 from the security lock using the master reset code,you can get the master reset code from here Simpleunlocking.com and reset it.......simply as the website name the master reset also easy.
are you going to change your lock or security code?if you wish to changer it,or are you trying to put a security on your phone.(* the default code is 12345)
just go to settings > security > lock code and enter your code (there's an option if you wish to change or edit your code.
hello 1_ can you save your formation in other phone . 2_that code format your phone for Nokia only 3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345 4_ other numbers *#7370# and the security n ...... and look if the problem is solve it because after this . you have like a new mobile
