Testimonial: "thank you for your assistance but firstly sorry i didnt mention it but it is a two wire and secondly i prefer a local company in south africa. thx"
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. Check the pump for debris first. If it is clear and turns freely it's the motor. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
Replacement motors for that pump are commonly available. AOSmith makes one with part #STS1102RV1.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
