Televison & Video Logo
r
rodger russell davis Posted on Dec 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jvc tv code for sony dvd player remote so i can use the sony remote for the jvc tv.
Trying to get code for the jvc tv to put in a sony dvd remote
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Dec 26, 2015
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008735
Points
237762
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
5 Related Answers
dbsb
  • Posted on Jan 05, 2008
SOURCE: Konka KLC 1508U TV
I am using a Phillips Universal remote I got at Target that controls 3 devices. The code for this is 0504. I have it hooked up with a cable box and in order for it to work correctly, I have to turn the TV on before I turn on the cable. If I don't, then channels don't change, etc.
Anonymous
  • 2712 Answers
  • Posted on May 05, 2008
SOURCE: Onkyo remote RC 570M
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
t-mac 1979
  • Posted on Dec 01, 2008
SOURCE: SAMSUNG BN59-00599A REMOTE
http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Pages 18-25 should be what you need.
Anonymous
  • 1959 Answers
  • Posted on Apr 15, 2009
SOURCE: code for emerson remote
I found this list for Jumbo Remote Control codes. Post back if they don't work for you.
http://www.jumboremotecontrol.com/remote_control_code_list.html
Anonymous
  • Posted on Apr 20, 2009
SOURCE: jvc remote control # LP20303-008
http://www.remcomplekt.ru/datasheet/rmt_pdf/codes/LP20878-009A.PDF
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
1helpful
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
I would like to program an older Samsung tv to my JVC LP21036-038 Remote I need the codes?
Unfortunately, the JVC LP21036-038 remote can only control JVC devices. It doesn't have any adjustable codes. You can choose between 3 codes (A, B, and C) so that using 3 JVC video devices doesn't result in conflicts. This remote came with the JVC HR-XVC14BU among other devices. The manual for the VCR/DVD player is available from JVC support. The direct link to the manual is http://resources.jvc.com/Resources/00/00/90/LPT1148-001A.pdf . See page 17 of the manual for the details.
I'd recommend you get a cheap universal remote to control the Samsung TV and the JVC vcr/dvd player.
I wish that I had better news for you.
1helpful
I have an icon universal remote..but i lost the code list.. now i dont know how to set-up my jvc tv and dvd player..pls help me..tnx
Here are the codes that you can try for your jvc tv:
  • JVC Codes: 013/ 054/ 055/ 060/ 065/ 067/ 089
  • 0helpful
    I lost my JVC remote control model DR-MV79B, This is a some kind of combo DVD/VCR. I tried a rca universal but didi'work
    Each universal remote have certain code for each TV, read the manual for code, match the code with your JVC.
    1helpful
    2answers
    Need URC code for One for All remote URC3030B05
    Hi Pal For The Jvc Try One Of These .....0067....0008......0041it should be one of them for the sony try...0032...0034....0000 let Us No If Not I Try Gen More...Roots
    JVC XV-S500 DVD codes
    Did you try looking on the net for your remote brand? Under PHILIPS UNIVERSAL REMOTE I found to codes for JVC dvd players: 242 and 443.
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
