Radio wires
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
SOURCE: i need the color codes 4 a 1998 dodge ram 1500 radio wiring
I am not sure for which wires set you are looking for.
You can go to www.autozone.com then go to repair info, and you can find your free online repair manual.
This is my main source for automible repair info
SOURCE: I have a 7 wire truck hitch ..I need the color
Yellow wire/left signal and stop lamp.Green wire/right signal and stop lamp.Brown wire runs the tail lights.White wire is ground.Blue wire goes to the trailer brakes and the break away switch.Black wire is a 12 volt switched power wire and the red wire is for back-up lights.
Testimonial: "Very quick and helpful--Thanks!"
SOURCE: Looking for a wire diagram with color in order to
check the fuses in the engine compartment. dodge has a separate (brake)fuse for driver and passenger side of vehicle.
For
more help on car radio problems, I suggest you to go through these
troubleshooting links, these will help you: -----
Click
the link below: ---
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
To reprogram the
radio there is 4 digit code. That code has to be inserted, once these code is inserted,
your car radio will get into its actual setting where you can set/select your
radio setting.
Many
a time's radio asks for the code after car battery is disconnected.
On
some cases to retrieve the code its mentioned in manual or else car
dealer is other option to get car radio code.
For
Click
the link below: ---
To reprogram the
radio setting.
Many
On
For
Click
the link below: ---
Can
car radio code block Passkey anti theft system ?
How
to wire new car Radio?
Radio
Stereo Wiring Diagram?
How to remove radio on Car models?
Where
is Radio Fuse located?
After
Market Stereo wiring?
car
radio doesn't allow to switch to the XM Band to get the radio ID?
No power to radio Scion Xb?
Radio has power but
no sound?
Radio goes ON and
OFF while driving?
Town Car Radio stereo wiring?
Radio wiring
diagram for Car?
How to remove cd
player from dash?
This will help.
Thanks.
