I have Nokia 3110c mobile phone. When I connect my phone to the PC through the data cable, only the files from memory card (extendable) are transferred to the PC.I am not able to retrieve the files or the information (like contacts) in the phone memory to my PC. How to transfer all the information from phone memory (not memory card) to my PC ?
When you are backing up your phone data thru Nokia PCSuite then it gives you an opportunity to select what all data from where all to be backed up. Select whatever you want.
Download the software from Nokia.com and also download nokia PC SUITE then connect the phone to PC using data cable. Make sure your mobile battery is connected to a charger because any interruption during software upgrade, will loose the entire mobile software and will never switch on again.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
This is what happens. Nokia 3110 hangs, gets switched off and restarts
randomly. More often, it restarts around 3 times or so and then gets switched
off.
Possible Causes and Solutions
Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has
got 9MB of internal memory. Solution - Keep the free space between 350 to 500 KB, so as
to keep things running smoothly on your phone and prevent Nokia 3110c from
restarting. Cause 2 - Changing Themes - Some people have reported that
the phone restarts automatically when they try changing display themes on the
phone. Solution - Don’t get your phone loaded with too many themes
downloaded from the internet or atleast, don’t switch themes frequently. These
themes, mind you, also load up things into your already falling Nokia 3110c
phone memory. Cause 3 - Memory Cards - Some people have reported that
Nokia 3110c restarts due to some issues with the memory card. Solution - Remove the card, get it formatted and then
insert it back and then restore factory settings. This just might solve the
issue. Cause 4 - Transferring data via Blueooth / USB data cable
(or) Updating Music Library - A few people have reported that their Nokia 3110c
mobile phone restarts when updating the music library. Solution - Don’t try updating of music library frequently
or don’t often transfer data in/out of your Nokia 3110c phone. Cause 5 - MP3 files Solution - This may seem dumb, but consider converting all
your MP3 music files to WMA and then store them on the memory card. Some users
suggested this.
Install PC Suite -
If not Done -
Check Settings From Phone - USB Device > Select Data Transfer or PC Suite -
Or Format ur Mobile n Check From PC if Connected -
IF Not Connected CHeck My Computer Properties -
Then go to Hardware > Device Manager > See the Device is there Connected or Not -
download nokia pc suit 7.0 from nokia website heres the link http://www.nokia.co.uk/A4630250
dont select storage device mode select the other mode. you also need to install drivers for your phone dont worry nokia pc suit 7.0 has it all. firstly install pc suit and connect your device
