The engine wont turn over i have good battery and good starer i went to jk yard goy ignition switch put it on it started i shut engie off and try to restart nothingno start i replace crankshaft sensor amechanic told me it could be a prndl sensor its in transmisson
Try cranking it in neutral.
Which part of ignition switch did you replace ? The key an lock cylinder or the electrical part behind the lock cylinder ? What year ,make an model vehicle do you have ? Most all newer vehicles from 1996 on have anti-theft systems . Is there a security light lit on your dash ? These same vehicles have a starter relay in the under hood fuse box that is turned on or energized by the PCM/ECM - engine computer . The switch the mechanic told you about is the transmission range selector or park neutral safety switch. Your best bet , rather then replacing parts is to take it to a ASE certified repair facility .
First check the starter relay fuse. Replace it even if the fuse looks good.
If it still does not start, jump the starter's two heavy solenoid terminals with a screwdriver. FOR YOUR SAFETY THE CAR MUST BE IN NEUTRAL OR PARK WHEN YOU DO THIS because the starter should jump and turn now! The ground is the problem if it turns.
If it still only clicks the solenoid may be faulty. Replace this if you did not get a new solenoid with the starter.
