Ovens Logo
A
Anonymous Posted on Sep 24, 2015
Is there a shabbath mode on this oven. if yes how does it work
Claude Kayser
Level 3:
Top Expert:
  • Ovens Master 9,098 Answers
  • Posted on Sep 24, 2015
Claude Kayser
Ovens Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067677
Points
28436
Sabbath Mode - Star-K Kosher Certification - Kosher ...
www.star-k.com/kashrus/kk-cooking-SM.htm
Whirlpool called this "the Sabbath Mode" and was awarded a patent in 1998 for ... In many cases this mode will prevent the oven light from going on/off as the ...
Testimonial: "what is the procedure to getting the sabbath mode to opperate on the kitchenaid superba selectra 27 self clean convection double wall oven. and subsequently how do you turn it off?"
  • Claude Kayser
    Claude Kayser Sep 24, 2015
    Look for a user manual on the web
HB13AB550B-61 fan not working
see if voltage to fan motor if no bad board if yes bad motor
Whirlpool WD 142 IX How do I get the demo mode off
To Exit Demo Mode:
  1. Select Try the Product.
  2. Scroll and select Explore
  3. Select the Tools keypad.
  4. Scroll and select INFO.
  5. Select Store Demo Mode and select OFF.
  6. Select YES on the confirmation screen.
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
1helpful
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Bottom oven not working, nothing comes on at all, though the display is flashing AUTO, and cannot change this as do not have manual. Thanks
It sounds like the oven is not working as the electronic timer is in auto. mode. It must be in maunal mode for manual oven operation. Turn the oven on. Muck around with the buttons on the timer and try all different combinations. This may take 5 minutes or more. When you do hit the manual mode the oven indicator light will come on and the oven will work.
Feb 15, 2011 • Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 • Ovens
Can you use oven cleaner instead of using the self clean mode?
yes but the self clean mode is less costic and is less exspensive.
6helpful
2answers
Jennair 30" wall oven display is totally off.
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Broilers suddenly stopped working
gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
Kitchen aid kebc278 dual ovens don't work
yes once of the door switches is broken you could jump out the switch
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
