Why is "push power protect" displayed? - Audio Players & Recorders
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
WHAT IS PROTECT PUSH POWER
When the switch on the system after 5 seconds hangs the device and the display, "protect push power"
1helpful
PROTECT PUSH POWER
When the switch on the system after 5 seconds hangs the device and display, "protect push power" push to reset.
3helpful
Have a SONY DAV DZ370 Home theater system. Displays 'Push Power Protect'. Tried 'cold reset' and all the manual stuff to no avail. Should I reset the M16C micro-controller or is there...
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
5helpful
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Message displays push power protect, pls help
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a lost contact.First try to resolder the pins of STK-IC if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
17helpful
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
12helpful
3answers
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
6helpful
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
 Grubhead
Grubhead
SmartAviator
SmartAviator
