Cars & Trucks Logo
Cindy Burgess Posted on Aug 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuel pump and filter located on a 1985 Ford Crown Victoria with a 5.0
Car died while driving, towed home, cranks but will not turn over. Parts house said I might have two different pumps either an in line electric or in tank. Any suggestions or diagrams would be great.
Claude Kayser
Level 3:
Top Expert:
  • Ford Master 9,098 Answers
  • Posted on Aug 19, 2015
Claude Kayser
Ford Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067706
Points
28436
2003 crown victoria cranks wont start, was running fine, just cut out.never started again
As with any no-start situation, you need to know if you have spark to the plugs, fuel to the injectors, and normal compression to proceed.
It have a 1994 crown victoria it ran out of gas I put 5 gallons of gas in it, when I turned the motor over it started right up, it ran for about a minute and a half then quit. I changed the filter, checked...
Air in the fuel line. Take one small wire off the starter relay and turn and hold the key in the start position for a while. Listen for the fuel pump. It will run fast for a second then slow down. When it does, put the wire back on the starter relay and crank the engine.
1helpful
Somthing is shutting my fuel pump down before the car cranks
Fuel pressure regulator may be bad,is normally located at the end of fuel rail.
let me know if this helps
1985 crown victoria stalls out
Why not hook a fuel pressure gauge up to it & see what the pressure is ?? Am I missing something here?
How do i know if the fuel pump is working on my 1988 ford crown victoria and if needed, how hard is it to change?
You can tell if the fuel pump is working when you turn the car to the "on" position, not cranking it over, but just on, you should hear the pump prime.
Im not sure how hard they are to change however, if it's an in-tank filter, you need to drain, and drop the tank to change it.
1helpful
Car dies when accelerate. do i need new fuel pump?
Hello;
It sounds from your description that the fuel pump is weak. To check the fuel pressure you need a fuel pressure test gauge for fuel injection. Attach the gauge to the test port schrader valve and turn the ignition to the on position. Record the reading. Now start the engine and record that reading. Unplug the pressure regulator vacuum line and record the reading.
The pump should have pressure with in specs but if low, start with the installation of a new complete pump. It is located in the fuel tank. Also replace your fuel filter.
Hope this helps you.
Thanks;
Rich
RPM Northwest
2005 Crown Vic Police Interceptor: Starts then stalls
Have you checked the fuel filter. Fuel pump will pressure up, but fuel filter could be clogged and not work without the pressure of the fuel pump.
2helpful
4answers
Where is the fuse panel on a 1985 Ford Crown Vic located?
Local Ford dealership service department provide answer on location of the fuse panel. Fuse panel is located directly under the steering column. The cover panel is held by two screws and the power antenna swithch locking ring must be removed.
thank you all for you assistance,
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
