In general dishwashers in a home setting use a very low grade of soap and cheep surfactants to get this simple job done.
Problem is that the chemical footprint or residue is not the same for the several different types of soaps that are available.
get three different makes of soap that you like the results of and alternate thru them to cut back on the residue
DO NOT'S
do not run vinegar thru your dishwasher
do not use lemon juice either.
in some markets there is a product called afresh that is made for cleaning out the dishwasher. try it.
for best results treat your hot water with a water filtration system and softening system. With this in place you may be able to cut back on your soap too.
SOURCE: Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
SOURCE: Whirlpool gold dishwasher leaves film on dishes
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
SOURCE: No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some
dishwashers have a valve (or gate) that should open only during
draining. If debris lodges in the valve, it can't close properly, so
water drains out during the wash cycle. Most dishwashers drain into the
garbage disposer. If yours does that, listen for water flowing into the
disposer during the wash cycle. If you can hear it then, the drain
valve may be clogged.
Spray arms
There's
a spray arm at the bottom of your dishwasher--it may have a tall spray
tube mounted to the center of it. There may also be a spray arm located
directly beneath the upper rack of dishes and/or above the upper rack.
If
debris is blocking the holes in the spray arms where the water comes
out, it could cause cleaning problems. Regularly inspect each of the
spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers
don't perform their best if detergent is introduced only at the
beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers
are usually wired directly to the home’s electrical system. To
disconnect the power, switch off the circuit breaker or remove the fuse
for the electrical circuit the dishwasher is attached to. Try to turn
the unit on after disconnecting the power to be sure you were
successful.
CAUTION: If you’re not sure you’ve
shut off the power properly, DO NOT CONTINUE. Call a qualified
appliance repair technician to complete the repair.
SOURCE: dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
SOURCE: Our kitchenaid dishwasher is not cleaning well
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
0--0
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
Here is a tip that
your dishwasher.
Dishwasher
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
