Every attempt to turn on the xbox 360 it gives an one red ring and a error code E74
E74 - This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between. Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit. Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip. Xbox 360 Error Codes Explained and How to Fix Them
SOURCE: e74 and 4 red ring Xbox 360
the a/v card is faulty, there is a chip called " ana or hana " and that goes bad.
the best solution is either to send it to microsoft " they will charge you around $ 100 - $ 150.- " to fix it, or to find the chip and replace it.
there is hope though try another a/v cabel, borrow one or something, your cable may be damaged. if the new cable doesn't work then " 100 % sure is the chip " is very common problem.
i have one with that issues and bought another 360 " broken " and i am going to try to switch a/v cards.
SOURCE: how do i fix my xbox 360 e74 error code
you can fix e74 wiht te same process as the 3 red light problem
SOURCE: XBOX 360 - E74 WITH ONE RED LIGHT
Try doing this steps:
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
* Turn the console off.
* Unplug all the power and AV cables from the console.
* Unplug the power cord from the wall socket.
* Firmly reconnect all the cables.
* Turn on the console.
If these steps do not resolve the behavior turn the console off remove the hard drive, and then turn on the console. If the error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
SOURCE: xbox 360 halo edition (e74)
i know what you mean..i have had three RRODs so far and no one ever physically examined my console..all they asked on the phone was:
have u made any modifications?no
have u plugged the power directly in the socket and not a power strip?directly,no power strip
what is the light status on the power brick?green
what is the light status on the console?the RROD!
have u restarted and reinserted the cables blah blah?yes no use
be confident and answer!!i got mine within a 4-5 days,a delivery guy gave me a new one and took the old one(he probably had no clue what an xbox was!!,and this was all three times)
i am from India and actually was quite surprised that i got a new one three times!
and the surprise was a sorry note from microsoft and 30 days of xbox live gold!!
call them asap and get urs pronto..GOW2 is coming!!
regards!any help let me know..
SOURCE: Xbox 360 error e74
hey everyone.. MS will warranty this problem. here is the link that they are including the error e 74 to the list of coverage warranties.
http://www.thetechherald.com/article.php/200916/3451/E74-Xbox-360-error-now-covered-by-Microsoft-warranty
At one
point 1 out of every 3 Xbox 360 owners experienced this
problem. This is the one error that you do not want to
get.
This highlights that there is a serious Xbox 360 hardware
problem.
Your options are to send your console back to
Microsoft for repair or to fix it yourself. Be prepared to
spend
a nice amount of money ($140 or so) if you are sending your system to
Microsoft and you no longer have the warranty
4 Red
Lights
If
you have to get any flashing lights on your Xbox 360, pray that this is
the one. If the entire ring flashes, it is a minor problem
that
indicates that the AV cable isn't connected properly or in rare
instances, the cable is damaged. Make sure everything is properly
connected and replace it if It still doesn't work.
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
