Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
