Sometimes the drainage tube will get clogged..
The drainage tube on the inside should be clear so you can see if its clogged & not flowing..
Is the water flowing to the end point of the drainage ?
They should be cleaned out once a year by using a shop vac from the outside.. The after that - disconceting and running bleach water through it from the inside.. This avoids cloggs that will definately happen..
Hope this helps !!
Please rate me good ;o)
