2000 Chevrolet Cavalier Logo
A
Anonymous Posted on May 21, 2015
Why does the anti-theft light stay on?
Run but don't want to drive it like this
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on May 21, 2015
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7112328
Points
73899
There is a problem with the system an there is a DTC - diagnostic trouble code stored in the body control module !
The vehicle theft deterrent system is designed in order to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is engaged by the correct mechanical key. The theft deterrent system uses the following 4 components for theft prevention:
The lock cylinder
The ignition switch
The body control module (BCM)
The powertrain control module (PCM)
When starting the engine, the PCM searches for a password from the BCM through the Class 2 serial data circuit. If the password is not recognized or not present, the PCM will disable the fuel injectors. Two modes of tamper detection are provided:
No password received
The engine will start and stall quickly. SECURITY telltale will flash on the instrument panel cluster (IPC) and then stay ON steady.
Incorrect or disable password received (More than 3 invalid passwords are received)
The engine is disabled for at least 10 minutes and the SECURITY telltale will illuminate solid on the IPC during the 10 minutes.
After the vehicle has passed theft detection, the PCM will continue normal operation
Ignition Switch
The mechanical key and lock cylinder is located on the steering column. The main electrical switching portion of the assembly is separate from the key and lock cylinder. The VTD portion of the ignition switch is the Passlock?"¢ cylinder.
The Passlock?"¢ lock cylinder is a locking cylinder that turns a magnet past a stationary hall effect sensor. When turned to crank, the hall effect sensor is latched which applies a fixed resistance to the Passlock?"¢ signal data circuit. The voltage measured by the BCM on the Passlock?"¢ signal data circuit is the Passlock?"¢ data value.
Body Control Module (BCM)
The BCM compares the Passlock?"¢ data value to a value that it has stored in memory. If the values match the BCM sends a password via the class 2 serial data line to the PCM.
Powertrain Control Module (PCM)
When the PCM receives the correct password, the PCM enables the fuel injection system, allowing the vehicle to operate correctly. The PCM may allow the car to start and quickly stall during a failed theft condition.
If the BCM does not receive a Passlock?"¢ data value, the BCM will enter a short tamper mode. During this mode, the VTD system will not allow the car to operate for 4 seconds.
If the Passlock?"¢ data value is incorrect, the VTD system will enter the long tamper mode. In the long tamper mode, the following actions will occur:
The THEFT SYSTEM indicator will flash.
The fuel injectors will be shut off for approximately 10 minutes.
Although the vehicle may start, the engine will quickly stall due to a fuel cut-off.
In the event of an open in the serial data communication between the BCM and the PCM or a failure in the Passlock?"¢ lock cylinder, the following actions occur:
The VTD system will become fail-enabled if the car has already passed theft for that ignition cycle (i.e. the engine is running).
The PCM or the BCM may set diagnostic trouble codes (DTCs).
The THEFT SYSTEM indicator will light continuously.
The PCM will become fail-enabled for future ignition cycles.
If a failure occurs when the ignition is off, while the VTD system is not fail-enabled, the PCM will never receive a valid password, and will not allow vehicle operation by disabling the fuel injectors. An this system can set 6 DTC'S
DTC B2947 Security System Sensor Power CKT Low DTC B2948 Security System Sensor Power CKT High DTC B2957 Security System Sensor Data Circuit Low DTC B2958 Security System Sensor Data Circuit High DTC B2960 Sec Sys Sensor Data Incorrect but Valid DTC B3031 Security System Controller in Learn Mode DTC B3033 Security System Indicates Tamper
My anti-theft system came on and my key wouldn't come out but it would start and my windows don't roll down and my sunroof doesn't open does that have to do with the anti-theft system
When the anti-theft system in your car is activated, it is designed to prevent unauthorized access to the vehicle and protect it from theft. The specific features and functions affected by the activation of the anti-theft system can vary depending on the make and model of your car. However, here are some common ways in which the anti-theft system can impact your vehicle:
  1. Ignition Interlock: In many vehicles, the anti-theft system can prevent the engine from starting or cut off power to the ignition system. This is often the primary function of the anti-theft system to deter thieves from driving the vehicle.
  2. Key Removal: Some anti-theft systems can also lock the key in the ignition switch, making it difficult or impossible to remove the key when the system is activated.
  3. Door Locks: The anti-theft system may lock or unlock the doors automatically when it is activated. This can be intended to prevent unauthorized entry.
  4. Windows and Sunroof: In some cases, the anti-theft system can disable the power windows and sunroof to prevent someone from gaining access to the interior through these openings.
  5. Alarm Activation: If your vehicle is equipped with a security alarm system as part of the anti-theft system, it may activate the alarm if unauthorized entry is detected or if someone tries to tamper with the vehicle.
  6. Vehicle Immobilization: Some advanced anti-theft systems can immobilize the vehicle by cutting off fuel or electrical power to the engine.
If you're experiencing issues with your key not coming out, windows not rolling down, and the sunroof not opening, it's possible that these problems are related to the activation or malfunction of the anti-theft system. However, it's essential to consult your vehicle's owner's manual or contact the manufacturer or a qualified automotive technician for specific information about how your vehicle's anti-theft system operates and to diagnose and resolve the issues you're facing.
In many cases, anti-theft system problems may require specialized equipment and knowledge to diagnose and repair, so seeking professional assistance is often the best course of action.
1helpful
I inherited a 2004 mercury marquis and after anti theft was triggered, car won't go over 40 and overdrive light blinks
If the vehicle starts an drives, even at 40 to 50 miles per hour the anti-theft system has nothing to do with this. The PATS anti-theft system on that vehicle disables the starter from working to deterrer vehicle theft, that's it.
overdrive light blinks ?? you have a transmission problem with the electronics .With over drive light blinking codes are stored in the computer . Need to hook up a professional grade scan tool an check for codes . Your best bet take it to a qualified repair shop that knows what it's doing.
The security light stays on, car runs and drives fine, but why is the security light on?
your anti theft device is activated,use your keyfob to lock and unlock the doors and then start your car,if you dont have a key fob,get straight to your car dealer,chevy,ford,etc,and have them program 1 for you b4 you cant drive your car
2helpful
Replaced the fuel pump. the car starts, but won't stay running
The anti-theft system will keep the car from being driven, so I would start there. You may need to reset the anti-theft or check the ignition key for problems.
I have a 1999 sunfire gt and it starts runs for a second and dies,my anti theft light on my dash is not blinking it just stays on,does anybody know a way to bypass the anti theft so that my car will r
Yes, unfortunately this is very common on GM vehicles. Go to this link for everything you need. Rule of thumb is this. If the light is flashing, the problem will be In the ignition or the smart transponder key. If the light is solid, the problem is in the TDM (theft deterrent module). This is the main computer for the theft system. There is a full bypass method on this link listed under PERMANENT FIX. This is what you will need. It will bypass every aspect of the system 100%.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
1helpful
Won't start and the anti theft light coms on. I been to the gm dealer 3 times after running a diagnostics on it still can,t find the problem. sometimes the engine will start and the anti theft light comes...
Thanks for choosing FixYa and welcome to the site. Did GM reset the anti theft system in your car? If it is going off, it will cause the car to not start.
1helpful
I am having the same issue with my anti-theft device in my 2003 Alero. Last year it stopped running and would not turn-over. $400 later, Brakemax said they just had to reset the anti-theft device. oK,...
the shop that told you they ripped it out only ripped you off unless they removed some aftermarket alarm system i,m a gm mechanic and if you remove the factory anti-theft on a 2003 olds alero it will not run ever again until re-installed make sure your battery is charged good turn igntion switch to run position but do not try to start security light should be flashing let car sit with switch on and light flashing for ten minutes light should stop flashing now start your car this is how to reset anti-theft was that worth $400.00 and again why let a bussiness named brakemax look at a no start condition keep on and you will be BROKE to the max HOPE THIS HELPS AND STAY AWAY FROM THEM YOUR FRIEND @ HELPMAX
4helpful
2answers
99 chevy cavalier theft system light on steady, car wont crank.
My 2000 cavalier has done this for 6 months. You take your key out then open your door, wait ten minutes and the system resets itself and the car will start-annoying you bet!!!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
