Does Samsung adater make Seiki TV work wirelessly?
SOURCE: Samsung WIS09ABGN LinkStick Wireless LAN Adapter
Do me a favor first, shut everything down and unplug it all the tv the stick and the router and get back to me, thanks, I don't want you to spend money if there is no need,
Gym
SOURCE: Hi guys, I have an
Right now the security on your LED is set to 64 bit wep - now you need to change security on LED to wpa/wpa2 and that will solve your problem .
Advisable :if you can make sure what kind of security is been enabled on your wireless router (wep 128 bit or wpa/wpa2 ) that will be more helpful for you to select the security on led - give a try with wpa/wpa2 .
SOURCE: How do I find the MAC address for my Samsung
Plug it into a desktop or laptop. If you have a router you can go into the router setting and that should give you the mac on the wireless adapter. Does it have a label like the model and brand?
SOURCE: samsung wireless lan adapter can't find network
Samsung server is your router ,
Use the DLNA and check .
Use a computer to log In to the router and check if the device is listed
( the TV with USB)
