hasindu anjana Posted on Apr 28, 2015
How to look up my inkel eq-6010c - Audio Players & Recorders
1helpful
Where is pre out im having trouble hooking up amp and eq
You have to use the TAPE 2 (or monitor) on the receiver. It will take two sets of RCA cables. Both the receiver and the EQ will have an input and an output.
  • Run the output/REC (from TAPE 2) to the input on the EQ.
  • Then, run the input from the receiver (TAPE 2 again) to the output on the EQ.
The EQ will have another 2 sets of RCA jacks to hook up a second tape deck (because you used the jacks on the receiver for the EQ). You don't have to hook anything to these if you don't want to, or don't have a second tape deck.
The receiver will have a monitor button, which most of the time is labeled as TAPE 2/MONITOR. Select whatever input you want to use (CD, Tuner, Aux, etc.), then press the MONITOR/TAPE 2 button. When that is on, the EQ will be in the audio chain - you'll be able to use the EQ to adjust the sound. If you turn the MONITOR off it will take the EQ out of the audio chain - the EQ settings won't affect the sound.
Keep in mind, the EQ will also have a button to select the TAPE 2 input. If you have a second tape deck hooked up to the EQ, this is how to use it. Make sure that the tape input is off on the EQ, if you aren't listening to that second tape deck.
How I fix code E000005-010105?
this is panel problem. this occured while timing on printing
How do I connect my SS-100SL EQ to my solid state stereo amplifier?my amp is already hooked up to my tuner with the rca jacks in the aux and tuner slots.my EQ has line in and out and tape in and out.the...
My first try would be:
Tape Out (amp) to Line In (EQ)
Tape In (amp) to Line Out (EQ
To kick in the EQ, you have to press the Tape Monitor switch on your amp. With the switch pressed, signal goes through the EQ, back to the amp and out the speakers. With the switch out, it bypasses the EQ.
If that doesn't work, you could try the Tape in and Tape Out on the EQ substituted for the above Line In and Line Out on the EQ
3helpful
2answers
U+ 070 English manual
i would to change the language setting of internet phone LG U+070 frommkorean to english how to do it
2helpful
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
My printer got uninstalled by mistake How do i
go to www.hp.com/support and find the driver for your printer that is compatible with your OS
1helpful
I have a GR-470 EQ. I don't think I'm connecting
The proper sequence to eq just your CD player is, CD out to EQ in, EQ out to receiver in.
2answers
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
2helpful
2answers
How do I connect a Marantz EQ 140 to a Marantz MR235 reciever through tape one (tape monitor) I am not confident that I have it hooked up correctly because I get music when the eq and tape monitor are on...
Dear driver800,
Don't you just love it when when someone who knows less than you do tries to answer your question? Why is it people who know little waste everyone's time with suggestions like "read the book"
On the back of your Marantz MR-235 you will find the RCA phono jacks marked Tape 1 Monitor Output these connect to the jacks labeled input on your EQ 140. The corresponding jacks labeled Tape 1 Monitor Input connect to the jacks labeled output on the EQ 140.
QED
Russ
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
 Grubhead
Grubhead
SmartAviator
SmartAviator
