It's marked LP PK R 15 amp , it's located in the instrument panel fuse box .
IP Fuse Block
Under the right side of the IP, near the rear of the IP compartment
LP PK R Fuse 15
15 A
Remote Function Actuator (RFA) Module, License Lamps, Tail/Stop Lamps, Tail/Signal Lamps, RH Side Marker Lamps, RH Front Park/Turn Signal Lamp
Thank you so much Jeff. Found it and issue solved
