Computers & Internet Logo
Rico Gipit Posted on Apr 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pin configuration of STK412-240 - Computers & Internet
Level 3:
  • Master 7,733 Answers
  • Posted on May 12, 2015
Master
Level 3:
Answers
7733
Questions
0
Helped
1865121
Points
21487
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
  1. Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
  2. Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
  3. Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
  4. Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
  5. Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
  6. Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
How do I Find the WPS Pin on the HP Printer for Configuration?
Being a new HP printer user, you might want to ask, 'how do I find the WPS Pin on the HP printer for configuration?' Well, here are the right steps to locate the WPS Pin. After turning on your printer, navigate to the screen of your control panel and click on the Settings. Now, tap on the Wireless button and then click on the Wi-Fi Protected Setup. Follow the on-screen prompts carefully and tap on the WPS PIN option. Your WPS Pin will now appear on the screen of your HP printer. After locating the pin, you can proceed to connect your printer using WPS Pin. https://connectmyprinter.com/how-to-find-wps-pin-hp-printer/
2answers
Hi, I got a tp-link 8901g, but no pin code exists behind the router. Only there is a P/N on its pocket with 10 digits, while I need a 8-digit pin for configure my wireless network. What should I...
If you are configuring your wireless network for the first time there should be no pin required, if there is it should be listed in the manual of the device. If you received this router second hand then you will most likely need to perform a factory reset on it to remove any passwords the previous owner may have set. The default login to the router to access all of the router configuration is user: admin password: admin. To factory reset the router you need to hold the reset button with a pin/paper clip while powering the device on and continue holding it for 15 seconds after powering it back on. This should wipe out all configuration and let you back to stock parameters where you can access the router at 192.168.1.1 and use admin/admin to access and reconfigure your wireless settings from scratch.
3helpful
3answers
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
I received a message about configuration wen i press enter it shows to enter pin number but i dunno what to enter i tried my pin number for mob but it didn't go thru i tried 1234 n 0000 but in vain wat...
Check the operator web page for Configuration settings, you should find the PIN there or Call the customer service, only them knows the PIN for the configuration messages.
2helpful
I have an old Magellan Meridian XL that has the power cable missing and I cannot locate another cable. Anyone know the pin configuration so I can make up a cable ? Power only, no data in and out.
Hi yakabofski!
There are TWO configurations of the pins with these units. We have the FIVE-pin config and the assignments are as follows:
Top pin- 12v
Bottom pin- ground.
Hope this helps.
P4 motherboard power pin configuration
Order you a schematic online for your TV.Cost $45.00 and some cost as much as $150.00
5helpful
3answers
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
2helpful
Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
Grand Canyon Tech
Grand Canyon Tech
