I set my lock code on my master lock speed dial lock and it wont open to the combo and i wantto know if i can reset it or something
if the lock is locked up and the combo that you set it to is not working then I would say that there might be a problem with the lock itself. I would suggest returning to the store that you bought it from and exchange it for a new one. if you want to try and get the lock open - you can try and progress the numbers, since you already have a combo set, this is a little easier then if you didn't have a combo at all. try setting the lock to the combo that you selected, starting with the first number - rotate the first wheel to the next number and try the lock and then to the next number and try the lock, when you get back to your original number, go to the next wheel and rotate that one around to every number ( testing the shackle everytime you get to a new number )---- repeat this process for the next two number wheels,, hopefully this will work,, but again it could be a broken wheel and I would just exchange it for a new one and start fresh.
here is an example of progression --- 1973 ( combo set )
1974,1975,1976,1977,1978,1979,1970,1971,1972 --
1983,1993,1903,1913,1923,1933,1943,1953,1963,---
1073,1173,1273,1373,1473,1573,1673,1773,1873---
2973,3973,4973,5973,6973,7973,8973,9973,0973 ---
I just used 1973 for an example -- if you want a more exact progression chart tailored to your combo, just let me know and I can write it up for you.
c...
