Fisher and Paykel SmartLoad DG62T27G Gas Dryer Logo
A
Anonymous Posted on Apr 07, 2015
Why does my reset button keep tripping on my dg6t7g
It works fine for a little while then the reset button trips
Jorgie the appliance guy
Level 3:
Top Expert:
  • Fisher Master 5,639 Answers
  • Posted on Apr 15, 2015
Fisher Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523920
Points
32630
I WOULD SAY A SHORT IN THE MACHINE OR THE MOTOR CAPACITOR IS BAD
MY RELIANCE WATER HEATER SHUTS OFF AND I HAVE TO KEEP PUSHING THE RESET BUTTON. HOW CAN I FIX THIS?
Why Does My Electric Water Heater Reset Button Keep Tripping? So the red reset button on your electric water heater keeps popping out and needing to be reset.
Here's the most likely problem: The water in your water heater is getting too hot.
When the water temperature in your water heater exceeds 180°, the red reset button (also known as the high-limit switch) trips. This tripping protects you from getting scalded or burned when using hot water in your home.
OK, but then what's causing the water in your water heater to get so hot? The most likely cause is a bad thermostat.
How a bad thermostat causes your water heater reset button to trip Electric water heaters have a lower and upper thermostat-one for each heating element.
The thermostats are responsible for controlling the heating elements. When the water has cooled off, the thermostats kick on the heating elements to heat the water. And once the water has reached your desired temperature, the thermostats shut off the heating element.
(This is very similar to the way your heating and air conditioning thermostat controls your home HVAC system.)
But these thermostats can go bad. When they do, they sometimes get stuck in the "on" position. This means that that the heating element continues to heat your water, eventually causing the high-limit switch to trip.
The fix: The bad thermostat needs to be replaced. A plumber can use a multimeter to test the thermostats and find out which one is bad.
Other problems that can cause your high-limit switch to trip While a bad thermostat is the most common reason your water heater's reset button may trip, it's not the only one. Other common causes include:
  • A shorted heating element-It may be that the thermostat is working just fine and shutting off the heating element. But a short in the element is causing it to continue to heat your water.
  • Loose wiring-A loose wire in the water heater can generate heat that can cause the high-limit switch to trip.
  • Bad high-limit switch-The switch itself may be malfunctioning and tripping when it shouldn't be.
Get a professional plumber's help
Do you live in the Minneapolis-St. Paul area and need a reliable plumber to help you troubleshoot your water heater problem? Contact MSP Plumbing. We can usually fix the problem the same day.
2helpful
Htachi ec89 Thermal Protection trips
Its your reset button on the compressor that's bad! I have the exact same compressor (EC89) and it did the same thing! Compressor would run great for 15-20 seconds, then trip the reset button. I ordered a new reset button off e-bay, replaced it, and it works fine now. Good overall compressor! but has cheep china electronics installed. just replace the reset button and you will be good to go....cheep fix!!!
1helpful
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
My toyota corolla 2006 model has the maint. required lights on. what does that mean?
It means your car needs an oil change, based on mileage. If you take your car to get the oil changed, they can reset the light for you. If you want the light off now, try holding in the odometer reset button, with the key on but engine off, until little dashes appear then one by one dissapear. This procedure may need to be done either on the odometer total mileage or trip A mileage or trip B mileage.
Step 1: Have car off.
Step 2: Push and hold in trip reset button.
Step 3: While still holding button in, turn key to ON, but engine off. Wait for the little dashes to appear and disapear. If it doesn't work on the odometer setting. before turning key off, switch to Trip A setting. If the procedure doesn't work on the odometer setting or Trip A, try Trip B setting.
Step 4: Turn key off. Then start car. Maint. required light should be off.
1helpful
2answers
How do you turn off the "Car needs Oil Change"
1. Make sure the trip odometer is NOT on 'Trip A' or 'Trip B' (ie: just the normal ODO). With the ignition off, press and hold the reset button. Press the 'Start' button twice without pressing the brake, but while holding the reset button. The dash will let you know its resetting, just keep holding the button until it is done.
2. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it
The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
4helpful
I have a 2004 Volvo S60. How can I clear the "Time for Regular Service" message. I service my own car.
Close all doors.Turn ignition key to position 1.PRESS AND HOLD trip reset button,immediately turn ignition to position2,keep trip button held untill trip is reset to 0.A yellow warning light will show when it is time to release trip button.Release within 4seconds ,a bleep will be confirm reset.Before you start reset, do not reset trip,If trip has been reset to 0,turn ignition to position 2 hold reset for 10- 15 secs untill previous reading is shown,then start reset.
2helpful
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Top Fisher Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fisher Dryer Expert? Answer questions, earn points and help others
