Cars & Trucks Logo
R
Rickie Brooks Posted on Mar 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OVERHEATING. THERMOSTAT GOOD. IMPELLER LOOKS GOOD. IMPELLER TURN WHEN THE ENGINE IS STARTED [REMOVED COVER]
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
  • Posted on Mar 18, 2015
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950914
Points
172802
The impeller of a water pump is inside the block so you would not see it turning. Have a compression test done to check for head gasket or cracked head
have a pressure test done on the cooling system to check for leaks.
Ian Summerfield
Level 3:
Master:
  • Master 502 Answers
Ian Summerfield
Master
Level 3:
Master:
Answers
502
Questions
0
Helped
133898
Points
1385
Blocked radiator fins,tubes,fins perished,.renew thermostat with genuine one.they are not worth relying on old ones.take it to a radiator specialist if radiator looks blocked.Sometimes dirt collects between radiatior and airconditioning radiator
I have a 2005 325i, my car started overheating all of a sudden, I noticed that I had a pin hole in the expansion tank. I bought a new expansion tank along with a new thermostat located in the bottom of the...
might sound stupid but did you check the impeller by holding the drive shaft and trying to turn the impeller asnif its a plastic one they tend to come loose on the metal drive shaft and loose power so they are not circulating the coolant ??
Not sure if radiator fans are working, car overheating. which fuse do I check?
LOOK UNDER THE HOOD IN THE ENGINE COMPARTMENT. ON DRIVER SIDE FOR FUSE BOX.LOOK ON FUSE BOX COVER IT HAS LOCATION FOR FUSES AND RELAYS.MOST TIME PROBLEM WITH COOLING FAN CIRCUIT WILL CAUSE CHECK ENGINE LIGHT.BAD ENGINE COOLANT TEMPERATURE SENSOR WILL CAUSE COOLANT FANS NOT TO TURN CAUSE OVERHEATING. ON.REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP SEE IF STOP OVER HEATING. IF ALL LOOKS GOOD HOTWIRE COOLANT FANS MAKE SURE FAN MOTORS ARE GOOD AND NO SHORTS AT FAN CONNECTOR WIRES.
1helpful
Overheating: 1999 bmw 323i m series 2.5 ..Installed: new water pump , thermostat. radiator,new Water Reservoir, cap.. hose on top side hot , lower hose cold even when engine is hot..no water circulating at...
the water pump and thermostat should have solved it. an air pocket can cause that but usually not to that degree.
don't get one of those cheap *** plastic impeller water pump for sissies. Get the metal impeller one. get a cool running thermostat and drill two 3/16" holes in it 180 degreess from each other. you may have installed the t-stat backwards.
2answers
MAZDA MX6 OVERHEATING, WHERE TO FIND THURMOTATE
follow both hoses to the engine at the end of the correct hose you'll have a screw clamp take it off and take off the cone metal tube cover(it looks like a half bowl and a 2 to 3 inch tube on it) it should have 2 screws on on each side the Thermostate is in it.
2helpful
2answers
HAve a 1996 Ford explorer v-8 that is overheating,
With cool engine... open radiator cap and look inside radiator. Do you see lots of sediment and calcium growth on radiater tubes? If yes, a coring may be needed. If only slightly bad, a radiator flush may be needed... then refill with 50 percent antifreeze.
Good thermostat, cleaned cooling system, non-leaking water pump, good water flow via water pump... nothing else left (unless you put the thermostate in backwards)..
Let us know
6helpful
2answers
Overheating
The thermostat is behind the upper radiator hose...remove the upper radiator hose and loosen and then remove the two bolts on the outlet (where the upper radiator hose ends) The thermostat is inside that outlet...Another thing to check is if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
1helpful
1992 Ford Taurus Overheating
Thermostat is faulty.
It can be found by grabbing the top radiator hose and following back to the engine. The housing this hose is clamped to is the thermostat housing. Remove the 2 bolts, and the cover o reveal the thermostat.
It should cost less than $20 for a thermostat and gasket.
Replace it and your overheating isues will go away.
Thanks for using FixYa - a FixYa rating is appreciated.
2answers
OVERHEATING IN THE COLD
sticky thermostat that the basic get that done as soon as possible overheating is very bad for the engine good luck pierre
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
