Westinghouse VR-3215 LCD TV Logo
A
Anonymous Posted on Mar 18, 2015
Input screen appears but will not let to scroll to selection
Vizio TV Input Menu Scrolling
Have you got any other remotes in the room that could be faulty or interfering with the WDTV.
Also:
try resetting via the side button with the unit on.
resetting to factory defaults via the internet menu.
unplugging the unit from power for some minutes (not seconds).
Do all the above one after the other before using the WDTV.
Sometimes this helps particularity after a firmware update.
The input source of the TV can be changed either through the supplied TV remote or physical buttons located on the TV itself.
Changing input source using the supplied TV remote.
  1. Press the INPUT button on the supplied TV remote.
  2. The input source screen will be displayed on the screen of the TV.
  3. Using the arrow keys, choose one of the input sources on the input selection screen.
  4. Confirm the selection by pressing the Enter button.
Changing input source using the physical buttons on the TV.
  1. Press the INPUT button located at the back of the TV panel.
  2. The input source selection screen will be displayed.
  3. To scroll through the options, press the INPUT button repeatedly. The last highlighted option will be chosen after few seconds.
3helpful
2answers
On a Panasonic DMR-EZ48V I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I...
I think it is usb, not sure why that happens though. Panasonic for some very weird reason mixes upper and lower case letters in some of their on screen bits, so you never know for sure.
I know nothing about this stuff but was having a similar problem with not being able to get the dvd recorder to record onto a dvd.
This was after I had set up the camcorder to the set the day before.
I finally went to 'input select' on the remote and changed it until it worked again, just go through each setting until everything is back to normal.
Somehow, it appears as if the dvd recorder got itself set to the camcorder and would not let go of that setting without changing the input select. I have no idea why because I never touched the input select before this, I always controlled everything with the Directv remote. Hope this helps someone.
1helpful
I want to change the language setting to English
Hello thanks for using fixya
To change the language, Follow the given instructions:
  • Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  • Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
  • Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
  • Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
  • Scroll to the language Select English and press the "OK" button.
  • Highlight the "Input language" field and press the "Change" soft key. Scroll to the language to English and press the "OK" button.
  • Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
You have done itFor further help regarding Samsung S3650 Corby Download its User Guide. It will help you alot
To download User Guide Click Here
Downloading will start after clicking on it
Guide is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
4helpful
2answers
I want to reset the LG shine 720
Hello thanks for using FixYa
To hard
reset of
your cell
Type 1809#*500# & select reset option which restores the factory settings.
A confirmation screen will appear, select Yes. It it asks security code then enter 0000 it will take some time and your handset will be restored to original settings.
or try this
to Reset Default
From the standby screen, press Menu
Scroll to and select Settings
Scroll to and select Reset Settings
Scroll to and select Master Reset
Your problem will be solved.
I have lg su 910 i forget my input password s.n/ 906kphg0179777 plese hhhhelp
Reset Default
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select Reset Settings.
Scroll to and select Master Reset.
Enter Security code, press OK.
NOTE: The default security code is 0000.
Clear memory
Scroll to and select Master Clear.
Scroll to and select desired option:
Handset
Memory Card
A confirmation screen appears, select Yes.
Enter security code, then press OK.
NOTE: By default the security code is 0000.
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I have to select or scroll...
I ran into this on a Panasonic DMR-EA38V, and have discovered that yes, it is one of the input selected with the input select button. It will select DVD, usb, SD (for SD card), and VHS. Scared me for a minute!
1helpful
How do i reset my LG CU 720?
Reset Default
Hopefully this will help.
Clear memory
Handset
Memory Card
please remember help me by giving me a good rating if you appreciate my help.
I need to delete 9 from the dialing string on an omni 3200
From main screen: Press first purple key on the left until you see Other Setup. Select Other setup. Input password (1, alpha, alpha, 66831 is most likely). Scroll down to Comm, select Comm.
From Edit CPT #1/2 press Slct. Press next until PABX Code appears. Press Edit. When you see New: press Enter. The field should now be blank. Press exit, then OK to save changes
From Edit CPT #1/2 press Next, then Select. Press next until PABX appears and repeat as above. When complete, press exit, then Clear until the default screen reappears.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
