Watches Logo
R Pea Posted on Mar 14, 2015
Need help with date change in a fossil me1135
4answers
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support [email protected]
hope this helps
4helpful
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
3helpful
2answers
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 • Watches
Fossil bq 9011349908 cannot set date and day
mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
4helpful
SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
17helpful
3answers
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
3answers
Setting the month,day, and date.
Alot of times on watches you can click on the stem one time and you can change the hour. Click on the stem and you can change the minute, date, and month.
Jan 04, 2008 • Watches
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
