I just bought a new motherboard from you guys. foxconn ela. everytime i turn it on i have no output signal. the lights and fans turn on. also on the bottom corner of the motherboard i have a code 09 or 60. does that mean anything. also i have 4 gigs(2x2) patriot viper series and a HIS Radeon 4850 and a e7400 cpu. are these coompatible. if you need more imformation let me know
One of two possibilities; the Motherboard or power supply. In my case it was the Motherboard. Those cheap capacitors tend to go bad over time without being used. I purchased a replacement motherboard(Foxconn RS 780 "bengal") from a place in WI. Skyline on Ebay. I would do a search on Ebay for Gateway Foxconn Bengal RS780 Motherboard. Then get the number and call. You can use the old processor, ram, and maybe the graphics card, but I'd run the onboard graphics first(if you do happen to have replaced the motherboard) to make sure the graphics card isn't causing an issue. You will need to do some research and reading on the net about installing new motherboards and hardware. If the motherboard is the same, Windows should still work with it. Do your homework first as this is only a suggestion as to your problem. It is what happened to my Gateway DX4300-03. Check all power supply related, graphics card and wire connections first before you consider the motherboard thing.
Do you have all the power supply cords fitted into M/board M/boards nowadays have 1 large white plug and sometimes 1 smaller 4 pin one or an 8 pin one Does your power supply have them if not you will have to upgrade tou power suplpy
Does your video card suit the motherboard they have different ratings 2X 4X 8X 16X if yours is a 16X and you fit to any lower number it will not work this is for both AGP and PCI-E
first check wheather power cable is join correcly at the monitor
then check video card placed correcly in agp card
or see the monitor cable join correctly at pc
