Zip Heaters Sylvania SA170 15 Amp Zip-Set Digital Wall Switch Timer Logo
M
Marsha Dollar Posted on Feb 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lights start blinking off and on throughout the night they are on.
Gene Haynes
Level 3:
  • Zip Heaters Master 5,391 Answers
  • Posted on Mar 31, 2015
Gene Haynes
Zip Heaters Master
Level 3:
Answers
5391
Questions
0
Helped
2606707
Points
14124
Following link has troubleshoot steps for common timers
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
ELECTRICAL ISSUE IN SUBURBAN
if the bridge (three diode that turn AC current to DC in alternator) is bad it causes internal draw
3helpful
Renault Grand Scenic - Dashboard flashing red light, clicking noise throughout car.
Hey,
You can try another battery if you have one, or take the battery to be tested somewhere to see if its at fault
Thanks,
Ekse
On my 1998 olds aurora, lights are coming on blinking in the middle of the night;killing the battery; have to disconnect battery every night
Your head light switch is the only thing that is capable of turning your head lights on, so I would replace it ! On the other hand you could have a mouse living in the dash, that has chewed through some wiring and at night when it is active it causes a short to turn the lights on. But I would would start with the switch lol
Samsung NX58F5500SS 30" gas stove 'door' light blinking and temp unregulated
-possibly temperature sensor has bad connection. Or bad sensor.
Good luck
mai
Dusk to Dawn Light Adapter
Might work. Might not. Depending if the eye can sense light and dark from that position. If area is shaded, then the sensor might think it's dark earlier in evening. If the area is dark, then sensor will not do as well, or might stay ON full time.
If the outdoor light shines on nearby surface, the reflected light might cause photo eye to blink on-off throughout night.. or not function as expected.
You can add separate photo eye to any light, and choose location for photo eye.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Add a comment and say what you discover, or for followup wiring question.
Jun 10, 2013 • Home
Solar cockerel light. the prolem is the light does not light up at night. I think the light sensor does not work, the light is on during daylight, the battery does not charge enough for the light to work...
Yeah, there seems to be something covering the light sensor causing the light to stay on throughout the day preventing it from having any energy to produce light for night. Good luck
Apr 19, 2011 • Garden
4helpful
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
97 honda civic - all lights inside & hazards blinking
sounds like a short in the alarm system
usually alarms will blink all lights when the alarm goes off
need to check the system with a scanner
Top Zip Heaters Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Zip Heaters Hardware and Accessory Expert? Answer questions, earn points and help others
