Master
- Posted on Jul 08, 2009
Re: Right front wheel bearing needs replacing,I see where...
Not sure if recall for 2005 models, I have one and the front bearings are packed in a hub, you have to remove the wheel, caliper and base and behind the hub theres 3 5/8" bolts, remove them and you will have a complete assembly removed.
Check with your dealer...they will run your vin # and see if the recall pertains to your vehicle. It is likely that in '06, they may have gotten a "bad run"of bearings or changed sources and gotten something less than expected when doing so.
