It is a mode that it stores what I'm writing, but not printing. I have no manual. How do I get it back in regular, normal typing mode?
SOURCE: Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
SOURCE: i have a swintec 8016. please tell me how to clear
Space all the way to the right press and hold the tab clear ket, press return, all the tabs should clear. Space to the points that you want tabs and press tab set. To clear an indivual tab tab to that position and press tab clear. DickyO
SOURCE: Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
SOURCE: swintec 8016 is typing wrong letter. May depress H
Check the pitch selection slide switch in may be in PS position if it isn't slide it up and down a few times they do get dirty.
DickyO
SOURCE: Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
