System is completely drained
Make sure all the drains are closed, start filling the rad and allow the coolant time to drain down, then fill again. Keep filling the rad unit it no longer drains down, just make sure to stop filling it when the level in the rad is just barely visible when looking down inside it. Now fill the overflow bottle to the lowest level mark. Start the car and turn you heater on to full heat. Let it warm up to proper temp, may/may not need to put more in rad. Keep an eye on the level in the rad it will expand and may overflow, if it looks like it will overflow use yout tester to remove some fluid. Once you see the coolant flowing throug the rad wait a few minutes, then put the rad cap on. Let it run a few more minutes to get the rest of the air out, then drive like normal. Check the fluid level in the overflow bottle (engine cold) over the next few days fill to proper level as needed.
