I have replaced the clutch brake switch the hand brake switch the belt tention and the resistance on the blue and green wires that run on this system i've made sure that all the pully's turn by manualy turning the deck i'm at a loss it's a good mower in great condition.
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Testimonial: "seat switch works as it should motor stops when you get of,put a new air cleaner and sponge cover which i put on yesterday,thanks for your input friend."
