Tip & How-To about Sanyo Televison & Video
1. REMOVING OF REAR CABINET
1. Remove the 11 screws [1], 3 screws [2] and detach the Rear Cabinet.
2. REMOVING OF CONNECTORS, SPEAKERS, STAND COVER ASSEMBLY AND STAND ASSEMBLY
1. Remove all the connectors from all the PWBs.
2. Remove 2 screws [1] and detach the Speaker-L and Speaker-R.
3. Remove the 2 screws [2], 4 screws [3] and detach the Stand Cover assembly.
4. Remove the 4 screws [4] and detach the Stand assembly
3. REMOVING OF PWB UNITS
1. Remove the 1 screw [1] and detach the R/C, LED PWB Unit.
2. Remove the 6 screws [2] and detach the MAIN PWB Unit.
3. Remove the 4 screws [3] and detach the POWER PWB Unit.
4. Remove the 4 screws [4] and detach the INVERTER PWB Unit.
5. Remove the 1 screw [5] and detach the KEY PWB Unit..............CHECK THE LINK FOR MORE INFORMATION
Electronics Equipment Repair Center
Do not attempt to remove more than one pushpin at a time.
To install:
This procedure applies to both the front and rear door panels.
// 0)
preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i];
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 30;
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog'];
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC';
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data';
var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Remove the pull cup retaining screw cover and...
... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Remove the two sail panel/speaker grille retaining screws and...
... remove the panel/grille from the door
The door panel is retained to the door by 11 retaining clips
Carefully lift the door panel off of the door and...
... detach the electrical connectors from the switches and remove the panel from the vehicle
