Heating & Cooling Logo
A
Anonymous Posted on Feb 13, 2015
Holmes hch6150 will not produce heat
So far, nothing
Happy Valley Air Care LLC
Level 2:
Novelist:
  • Expert 199 Answers
  • Posted on Feb 15, 2015
Expert
Level 2:
Novelist:
Answers
199
Questions
0
Helped
61972
Points
316
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
I need a remote and filter for HCH6150
Here is a link to your heater manual.
Here is also one for Holmes Customer Support.
Sites holmes products Site
Holmes HCH6150 Product Manual
HCH6150 heater runs for a bit and then just stops
Open it up and clean with an air can, most common cause is due to overheating.
2answers
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
I need to order a new quartz element or tube, the part that produces the heat. my email address is [email protected]
These heaters do not have off the shelf replacement parts and were not designed to be repaired/serviced in the field. But, you can return it for repair. Go to www.holmesproducts.com
for more info.
I'm trying to locate a user's manual for a Holmes Comfort Triple Ceramic Tower heater (model # HCH6150)
Contact the MFG. of said unit. They will send you a link for a PDF file to view for your unit. :-)
Nov 06, 2010 • Vacuums
14helpful
IIcant find parts for the holmes heaters. Who carries them?
I have the same problem. I mean it keeps going off prematurely. The heating area is relatively clean and there is no reason for this other than the Thermal Circuit Breaker to be going bad.
I too have fruitlessly tried to find the part. It is made by Klixon and the info about it is as follows: 1NT15L-4165 It is a manual reset bimetal temperature circuit breaker. Mine says L86 L = Limit and 86 I believe represents 86 degrees Celsius which is about 187 degrees F for us Americans.
I found the Klixon people and they told me the part was not available through them; but only through Holmes themselves. So, I of course called Holmes Customer Service.
Turns out that I had a little spat with Holmes' CS Jerky... She informed me that Holmes does not sell parts and that the heaters they build and sell are not serviceable. So, I argued that they are irresponsible with regard to the environment. What, it's supposed to go to a landfill now?
But she insisted that this was so that people didn't start fires with their heaters. And she says that she has two young girls at home and wouldn't want anyone burning down their house and killing their family. So I guess after all that has nothing to do with her keeping her job by Holmes selling me another $79 heater, huh?? lol Yeah right!!! Because the guy at corporate would not want one of their heaters to start a fire. That wouldn't be an acceptable risk to make money. (Sarcasm, in case you missed it)
On another note... It's real unfortunate that you have to take the HQH307 completely apart to clean the heating area so as to not have the heater be a fire hazard. But I'm a risk to my family by taking the thing apart and then removing the two retaining screws out and two wire leads off to replace the malfunctioning part. WTF??? Since I can't get the part I suppose I could just bypass the circuit breaker. I know that's not a good idea.
Well, bottom line is, (can ya take a guess?), that I will not be buying another Holmes Heater EVER!!! Thanks Holmes...
Answer: As far as I know you cannot get the part.
If anyone has a lead on the part please let me know here.
Thanks, LightningMan
Top Heating & Cooling Experts
Paul Carew
john h
