Many devices have "sleep timers" to turn the appliance off after a period of time during which you have supposedly fallen asleep.
This setting is configurable. Break out your manual, or find one online to find out how to enter this setting.
You might also try your remote, looking for some button cleverly disguised as "Sleep", or some such. Might also be hidden in a configuration menu somewhere.
Sounds like a component inside is overheating. Might suggest taking to a car adio specialist to fix but could be expensive to repair. A new replacement maybe cheaper.
Check if its in the hibernate mode instead of sleep. there's a short cut key to resume for hibernate check the user's guide in the laptop manufacturer's website.
you should access the menu or the sleep setting on your remote, it may be set on 20 minutes after that time is up it will shut off without notice. hope this helps
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
Well, for the CSD-ED27 the sleep works like this: 1. press STOP/MEMORY and then also 2. press PREPEAT/FM MODE/OSC 3. your display will show 10 4. use the tuner - & + to good from OFF-90 mins
As to you CD player not playing: it is sounds like the spinner might be not spin completely flat to the optical reader. This happen with my portable CD player, however at this time I do not have a fix for you. Good luck though.
