Car makes rattle noise when going over tiny bumps at low speed. Also makes a loud squeaking noise when turning the wheel left when moving and not moving . ( guessing ball joint )
Ball joints don't make noise. thy either work or they don't. when they don't you can have a crash since the ball joint holds the spindle in the correct angle. a squeaky noise could be from a lot of things. strut, spring, stabilizer, bearing, brakes but that would be when moving, cv shaft you would hear a clicking noise when turning a corner
IF NOT TRY SWAY BAR BUSHINGS
SOURCE: replacing a front wheel bearing
did you ever get this problem solved - i want to do mine, too.
[email protected]
When's the last time the tyranny filter was changed? I had noises like you talk about....turned out to be my trans filter and fluid needed changing!
