Pride Mobility Products Pride Victory 10 - Three Wheel Logo
D
Dennis Sullivan Posted on Jan 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Victory three electric scooter and it will not go forwards but does go in reverse just fine. Could you tell me what and how to check it to find the problem?
Just checked the connections
Rob Hill
Level 3:
  • Pride Mobili... Master 1,480 Answers
  • Posted on Jan 26, 2015
Rob Hill
Level 3:
Answers
1480
Questions
0
Helped
518186
Points
3838
Hi , if the scooter goes into reverse okay , it could a be throttle issue , or the forward logic( mosfet out put ) of the PG Drives controller has failed...
I offer free testing if based you're in the UK...
Regards
www.gewizrepairs.co.uk
Were is reset switch
It's usually a white button down at floor level between your heels
When i go forward or reverse i get a click the scooter does not move
Please check near the rear to ensure the the scooter is in gear. There should be a switch that needs to be moved up/down. Let me know if this is not the issue.
Good Luck!
1helpful
Scooter will just go in reverse and stay in after
Hello,you need to get someone to refit your forward reverse lever.im disabled myaself.please give me a thumbs rating 1 to 4.i do this as i care not for profit Colin.
2answers
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
1helpful
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
2answers
When I switch my mobility scooter on lights etc all work but no drive
hi, I first suggust you make sure that Freewheel is disengaged,
to test this try to push the scooter forward if it moves forward move the lever ,
Check the Wigwam or throttle controls to make sure they are not loose,
Check for reset switches under the seat or on the steering stem,
Check for car type fuses under the seat.
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
How dose my scooter stop
right, what scooter is it, You can try putting it in reverse slowly and that will bring your scooter to halt then reverse so take care, what brand and model of scooter ? Regards GeWiz
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
