SOURCE: need a diagram for husqvarna model lth-130 mower deck belt
Here is a diagram I have found for you.
SOURCE: my husqvarna lth 1342 tractor stalls when the
Hello james_3228:
>>If this Unit is Stalling like Someone has Turned Off the Ign Switch, then the Seat Safety Switch is Bad or has a Bad Connection.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
>>If the Unit is Jerking and then Stalling, then Check the Ground Drive Belt and Pulleys.
>>The Belt May be Caught between a Pulley and the Frame or Belt Guard or a Pulley May be Frozen and Causing the Engine to Stall.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View.
>>For Better Assistance, Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Mower Runs briefly then cuts out and wont restart.
These ride-ons have a cut out solinoid under the carby that when there is no power or the ign is cut it will drive a little pin into the main jet to prevent flooding, id say this is why your mower runs for 20 and stops...
There is a few reasons this could be occuring:
#1First I would be checking the battery see if its dropped a cell or has a dead cell, you can do this by load testing it with a load tester or removing it and taking it into a battery specialist. if this is the case the battery will not accept a charge from the charging circuit...
#2 Check your wiring with a multimeter from the armature under the flywheel all the way back to your battery (also these models may have a regulator/rectifier that can be tested they have test values and can be checked by your local small engine repaier)
#3 If all your wiring is ok then you will have a problem with your armature this is located under the flywheel on your engine it has two seperate windings one for the charging of your battery and the other powers your headlights / elec magnetic clutch, the one for the charging will be unservicable these can be diffucult to access and test and is probably best done at your local small engine repair shop...
Hope this helps you out
Kind Regards
Brad
SOURCE: We urgently need a front
The best solution for you from the United States is http://www.jackssmallengines.com/customer-service.cfm.
They will ship internationally.
You will need your model number (I think it's under the seat) to place the order. If you have the part number out of the owners manual it will speed up your ordering process.
SOURCE: I have a husqvarna Lth 130 riding mower need atop
you should be able to get online from husqvarna
