Vacuums Logo
Bill Felts Posted on Dec 24, 2014
How do I reset a Tornado CK14/1 PRO Vacuum - Tornado Vacuums
Tornado Piranha 2-Speed Floor Cleaner Machine will not turn on
If you get nothing on any speed, the first thing to check is whether you're getting power. The most common failure is the plug ( the part you put into the wall socket ) You can buy a replacement plug at any hardware store or you can take it to your local vacuum repair shop and have it fixed.
What is a tornado
a tornado it a brand of vacuum cleaner perfectly safe to be around
Tornado cv30/1 wont turn on
After changing bags my tornado vacuum will not restart
Replace belt
Is Tornado the brand name of the vac or just the model name? And I will need the model number to look up a schematic for it. Thanks
Tornado vacuum overheating
Overheating can be caused by several things. First check the bag and filters, clean or replace them if needed. Also check the suction path for any clogs or obstructions. Most vacuums have a thermal cutoff designed for safety to turn off the motor in the event of getting too hot. If all of the above does not solve the issue, the next to look at would be electrical connections and checked out by a qualified technician.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
I have a Tornado cordless chain saw. I have lost user guide. How do I oil this chain saw?
Google on line and ask for a user manual giving the name, product model number of equipment you are in need of an instruction guide.
1helpful
Can I get a parts book on the Tornado Karcher CW50? I need to order parts. Thank You
Karcher doesn't publish a parts manual, but there are numerous sites like this one that offer diagrams and allow you to order from a picture.
Tornado wide area commercial vacuum
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Why does the Eureka capture plus pet lovers put off a loud tornado siren sound when you turn it on. I cleaned the filters checked everything and it sounds like a tornado siren in the south. Email...
I would check your fan and see if any of the blades have been fractured. I had this happen recently when my vacuum caught a screw and the sound and vibration was deafening.
Top Tornado Vacuums Experts
john h
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
