Question about Tornado 93030 Wide Area Carpetkeeper Upright Vacuum
Tornado wide area commercial vacuum
Brushes wont turn suction motor works fine
Posted by dethridge72 on
Anonymous
  • 438 Answers
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Posted on Apr 16, 2010
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
Agitator wont turn
It could be one or more of a few causes. Easiest to check is the belt and/or brush roll. There are two switches for the brush roll. Both must be working properly. One is by the main power switch and the other is in the motor compartment. If the problem still persists check the brush bar motor in the power nozzle assembly
Feb 23, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Oct 14, 2007 | Vacuums
Tornado 93030 Wide Area Carpetkeeper Upright Vacuum Logo
Top Tornado Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
