If it is an Android phone just go to settings and turn off Airplane mode. Unless the sounds have been muted, then you have to go under sound and un-mute the sounds.
U should be able to go to ur settings and find sounds, there should be a drop down with all ur sounds, my phone is relatively basic but has those features, good luck
Go to Menu->Settings->Phone profiles. Highlight your profile and go to Options->Edit. On the "Phone Sounds" tab (the last one), set the Phone sound volume to 0.
Michaeladatu hello You may have all your sounds off on the phone. First you can do a simple battery pull of the phone. It will do a soft resetting of the phone for you. IF that doesn't work go into your menu of the phone go to the settings and then look at the alerts or sounds. Look for notifications for the txts and other media sources. If you go onto smasung websirte see if they have updates for you phone.. The omina pro has been known to glitch out on occasions. Software update mey solve your problem also.
Hit "menu" Go to "sounds" go to "ringer type" select "calls" select "downloaded"
Any saved sounds that you have in the phone will be here. If they are not there, and you received them in a pic or text msg, you will need to go back to that msg and choose "save sound" in the options.
could be two things, either the sound file is corrupt. or more likely, especially if you have multiple sound files producing the same results, your loudspeaker is torn or damaged.
You can most likely go to youtube and search for a video on how to take your phone apart. go to ebay and shop for a loudspeaker for that phone and replace it.
