SOURCE: my V6 1992 PATHFINDER IDLES RICH AND SURGES AT IDLE.
You need to Replace your Gas Cap. The Seal is worn and it is allowing Air to get inside the Fuel tank Causing your Rough Idle.
SOURCE: opel corsa 1.4i car cuts
My Opel corsa Lite 1.4i, 2005 model cuts off when idling or stopping. I've replace the ignition coil as it was suggested but the next day the problem continued. I've replace plugs, filters, ect. When I'm approaching a place where i have to stop i see lights on dashboard coming out and the engine goes off if i stop or if i put the second gear it kicks again. Please assist as none of mechanics in my area know where to fix now.
No idea offhand to be honest i would need my head under the bonnet to know what wrong .could be anything from the gauze filter in the fuel tank on the bottom of the fuel pump becoming chocked up and leaving the car allows it to drop away to a faulty pump overheating or the contacts ,maybe even a ignition module overheating ,Best advice is ask a local mechanic to have a look for you as normally these early opel corsas with the 4 cylinder engine are bullet proof they are even valve free if the timing belt snaps .
Sounds like you not getting enough fuel. Try replacing you fuel filter which sits under neath the rear near the tank. Just follow the line from the tank and you'll see it or it can be a faulty fuel pump You should get 3 bars pressure from it.
