Replug all the cables associated with the input and output of the main woofer. And check your system sound level from control panel and do increase it, hope this will help to solve your problem.
Actually the door speakers( less than 50W) do not need high wattage speakers as they are mainly powered from the head unit. Unless you are powering with a power amp a speaker of 300 watts is not required. But if the mountings are correct , the impedance of 4 ohms is correct, then it will fit OK and work. The only main issue will be the sensitivity issue of the speakers to work with a low output.
I have considered that a highly sensitive speaker( small voltage response) will sound great like an expensive power amplifier and high wattage speakers. Jensen had some good ranges in the 80's but now we have hard suspensions with poor response.
So my final suggestion is if powered from your head unit test it , there is no damage but if there is a response problem if you are a soft listener. Other wise there is nothing to worry on as the amp will handle except your listening pleasure.
So test to decide. Credit me if this info is helpful.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The problem with this wireless!
head set cutting out on the left side is very common for this model. I fixed
mine by removing the soft ear cup then the two screws under this cup then
carefully pry that top piece off the next lower piece. It will come but it is
stuck with some soft glue. Next, unsolder the two
wires on the back of the speaker taking note of the polarity. These wires are
what are broken. Undo the screw in the center. With a small screwdriver
carefully pry the pivoting cup off the ear piece. It is snapped onto a small
ball joint under the screw. Now remove the four
screws and remove the top of the ear piece. Remove the two screws
from the small printed circuit board and unsolder the two speaker wires. You
will need to find some new wire that is flexible and not much bigger in
diameter. I used some that was too large and had trouble getting the last cap
that holds the soft ear cup back on. I also reamed out the holes in the cap and
the cup that the wires go through to give them more movement. Replace everything and
solder the wires to the speaker in the same order as removing. You will need a good
small tipped soldering iron. Good luck Calvin
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
your receiver left fuse is blown, check if it has a user fuse at the back. or
your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Check your "Setup" in the main menu of the receiver. Press "Menu" or "GUI" whichever you have on the remote and go to "Manual Setup" then toggle to "Audio" then "Speakers" then toggle to "Center Channel" and make sure it's on "Large" or "Small" instead of "None". If you still don't have audio, post a comment with the model # of your receiver, I'll pull the book and help you further. Hope this helps.
You probably have the polarity on your plug to the transmitter set on the wrong one. Set it to negative frequency, and it will probably work. I've had the same problem myself.
One other possibility: the Music has to be coming through for the light to go on, so if the music is too soft, you might not get any sound through. Good luck!
More than likely the small spaker inside has siezed up!
You can puchase a replacement (search ebay for replacement speaker tomtom) for about 10GBP.
They are easy to replace - 4 screws on back of 710, pop out main unit, and remove 4 screws holding speaker, unplug and install new one - reverse to assembly once more.
I had a strange experience in Vegas when I took my tomtom710 on vacation. the tomtom was silent in the UK - speaker dead as a doedoe, however 3-4 hours in the Vegas heat on the dash made the speaker pop back into life!
Result I thought, however on return to the UK the temp had returned to below miserable and the tomtom didn't wanna play ball anymore.
So, tested the output internally with another temp speaker, all works fine - so just ordered a replacement "original" tom tom speaker to fully fix.
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
