Shift interlock to get car out of park
SOURCE: Honda Accord Lx won't shift into park or reverse
it should be the shift cable that doesnt let u put it in park
SOURCE: 98 Civic Auto Trans Slippage
you need to replace clutch pack for that gear can be ordered seperately from parts store or dealer if you want to save money call peach street auto recycling at 1800-365-2341 for a warrantied used one! also might be time for change trans filter and fluid filter could be slightly clogged but I lean towards clutch pack I replace these alot on Hondas
SOURCE: 92 Accord Automatic shifting
Has anyone change the transmission fluid and used anything other than Honda ATF-Z1. If so, have the fluid/filter changed in this car and use only Honda Fluid. This is the only fluid that you can use in a Honda. Even if you have used the correct fluid an fluid/filter change may help. If that is not the case then I suggest you seek out a trusted professional.
SOURCE: honda 1998 accord 4 cylinder will not shift out of park
Most likely the switch on the brake pedal, because you have to push the brake pedal first to get it out of park, Right ?
SOURCE: Car wont shift into gear. Gear shift moves but gears don't
It sounds like the lever from the gear shifter has come loose. I would first look at the shifter from under the car. You can also remove the boot (or console) from inside the car and check the linlage. Most linkage is held on by a small clip or cotter pin and somethime they don't stay in place anad the linkage slides off the arm..
