m.idrees Posted on Nov 16, 2014
I have dell a425 transformer is dead i need transformer howmany volt out
Joe
Level 1:
  • Contributor 55 Answers
  • Posted on Nov 25, 2014
Joe
Contributor
Level 1:
Answers
55
Questions
0
Helped
18725
Points
89
The total watts is 30W RMS... watts = volts x amps Using 240v ac gives: 30=240xamps Amps=30/240 = 0.125 amp or 125 ma. Short answer is disassemble to check the wiring on the transformer.... a wire may be disconnected. Check using a voltmeter the input to the transformer and the output (if any). You have to do a bit of simple fault finding I afraid.
Schematic Diagram for A425 amplifier
Did you ask Dell for help? Just don't hold your breath - they would rather you get a new one from them but U can try. If nothing, check it out on Google - might get lucky!
tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
I need the driver for it, i have no sound
Anonymous,
There are no drivers for the A425 speakers. Make sure the power cable is attached to the speakers as well as the speakers plugged into the correct jacks. If your speakers are plugged in and powered on and u still have no sound; check to make sure the sound card drivers are installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
1helpful
Dell a425 disassembly
I found this URL for you that shows a Dell forum where you could probably get all the info you need. It also has specifications for all the internals should you need to replace something. Good luck and be safe. I learned to hate capacitors a long time ago. :-) http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
Dell a425 speakers manual
How to open a425 subwoofer
pull off front plastic grill to access four screws on the speaker itself. Unscrew 10 screws on back to pull out the power board. The transformer is screwed to the bottom (4 screws).
2answers
My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
1helpful
5answers
Speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
[email protected]
 Grubhead
Grubhead
SmartAviator
SmartAviator
