CAN'T GET ANY CHANCELS TO WORK
SOURCE: Apex DT250 converter stuck in standby mode
I just had the same problem and replaced the popped capacitor and it works. I had to use a 470uf 35 because radio shack didnt have any 25's. It only cost $1.59 so i bought 3 just in case it happens again
SOURCE: Apex dt250 digital convertor-- light stays red and
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
SOURCE: i have a apex DT250 and all of a sudden my tv
The
DT250 has one or more bad 470uf 25v capacitors. You should replace all
four. Look at some of these youtube videos for how do do the
replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
