I've tracked the problem to this: the water in the tank flows out slowly , continuously?? When I shut the water intake, the tank will empty!! Wastes a lot of water and, if water intake is not shut off, it continuously refills producing an aggravating and never ending pshhtt sound of the water trying to refill. ?? Solution, other than changing the toilet???
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
How do you get at the flapper in this toilet. I never seen this type of filler mechanism are. They unique to water ridge?
Where can you get parts and how do you remove the flapper?
Wow - I have never seen a canister style flush valve mechanism before. Check this video to see if it helps:https://www.youtube.com/watch?v=m8Lw30ay...
SOURCE: Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
SOURCE: when toilet is flushed the toilet slowly drains
flush valve has obstruction and tank is not filling all the way to just below overflow tube.
I found how to correct the problem. I managed to disconnect the tower apparatus without breaking it, You have to turn it counter clockwise for a couple of clicks and it will come off. The problem was the gasket of course. It had absorbed water into it at one eight of its circomference. Not having a new gasket which I will search for, I just pierced one side of the gasket, emptied the water and put it back into place. It now works (for a while until I get a new gasket). Hard to imagine that a gasket could fill itself partially with water and therefore not have a good seal!!! For your info. Tx.
