20 Most Recent Toto Aquia II Dual Flush Toilet Questions & Answers
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Toto Aquia II... | Answered on Jun 26, 2019
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Toto Aquia II... | Answered on Aug 13, 2018
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Toto Aquia II... | Answered on May 29, 2015
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Toto Aquia II... | Answered on Jun 17, 2014
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
Toto Aquia II... | Answered on Jun 10, 2014
Your inflow valve is probably clogged. This is what allows the water in and how fast. You can change this also for a minimal cost.
Toto Aquia II... | Answered on May 07, 2014
Could be a few reasons, an ill fitting or cracked dress cover can sit to low, or abrasive wear and tear can grip the button restricting it from free movement. I fixed mine by placing a couple of small fishing sinkers in the bottom of the plunger giving it a little more weight.
Toto Aquia II... | Answered on Apr 30, 2014
Toto Aquia II Dual Flush Toilet Logo
121 questions posted
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
View Most Popular
Toto Home
  • Toto Home
Most Popular Question
toilet buttons will not come back up
  • Home
