SOURCE: 2001 Dodge Neon won't start. says "fuse"
check all you r fuses. There should be 2 sets, one under the hood and another in the passenger area(driver side under dash usually)
SOURCE: 1997 dodge neon. replaced coolant temperature
1997 Plymouth Neon, have replaced radiator, radiation cap, thermostate and hoses, still run hot. Fans do not seem to come on, where is the temperature sensor on this vehicle?
SOURCE: I need a wiring diagramfor the stereo on a 2001 dodge neon
Sorry to say there isnt one available (if its the factory stereo)...the only diagrams available would be for the wiring in the up to the connector at the back of the radio
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: 2001 Dodge Neon about 42,000 miles. Horn won't
a bad ground could cause that , or your horn could be going
SOURCE: Dodge neon 2001 will not crank at all. battery is
solenoid is part of the starter so best bet is to remove and have tested at an auto parts store.
