SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
SOURCE: zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
SOURCE: I have a hunter ceiling fan. The motor works fine,
NO YOU DO NOT !! there is a little black box on inside of fan that controls the lights, its a ( watt governor ). just remove this black box and wire directly to the lights. problem should be fixed !! have a good day !! this is another goverment quick fix.
